brake booster - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2008, 06:36 PM
brake booster
Brake booster....should the piston/center rod move in and out freely when it is not installed and no fluid present?....i have this old booster laying around and I was going to install it but I can not get the center rod to move in and out for anything....i even put it in a vice and it wouldnt budge.. im afraid if i install it the pedal will be stiff and not move an inch...any suggestions?
Thanks
Old 10-26-2008, 07:14 PM
Paul Marion
Last journal entry: 1935 Plymouth Pj coupe
booster
It's a linear movement. I'd prob. R&R it. brake fluid is the most corrosive fluid. I can imagine the physics of leaving a cap off & the rate of dissimilar metal corrosion. It's a bore, you can soak it in penetrating fluid for a day 1st. brake fluid is evil !!! 666 it will corrode everything It's almost as destructive as a ceo. Once it gets it's hooks in, it starts to drain the life out of everything around it. They both need to breathe in oxygen to tempt their destructive mindsets.
Old 10-26-2008, 08:21 PM
powerrodsmike's Avatar
Wiki Edits: 161
Yup, sounds stuck to me too.
A vacuum booster does have a fairly stout spring, but a properly functioning one can be moved by hand.
Later, mikey
BE different....ACT normal.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
1997 blazer..Brake booster gone bad? RodFather Suspension - Brakes - Steering 2 06-17-2005 01:26 PM
brake booster size pigjamelectric Suspension - Brakes - Steering 3 05-08-2005 08:44 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
