Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake Booster
Thread: Brake Booster
  #21 (permalink)
Old 04-19-2012, 09:42 PM
LBL's Avatar
LBL LBL is offline
Learning the Hard Way
Last journal entry: WOW
I'm Back
I switched out the motor and now I have bench bled the master cylinder and it looked fine. I put it back on the car and started bleeding the brakes, starting with the pass rear and then the drivers side rear. Everything is going well. I move to the pass front disc and there's no flow. I remove the line to that caliper from the proportioning valve and pump the pedal, no flow. I remove the line into the proportioning valve from the master cylinder and no flow. I am at a loss at what to try next..
