Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake Booster
Thread: Brake Booster
  #29 (permalink)
Old 04-26-2012, 08:35 AM
1971BB427's Avatar
1971BB427 1971BB427 is offline
Originally Posted by JeffB
This is the most commonly used master cylinder sold with most aftermarket booster combos,check out the picture http://www.ebay.com/itm/Master-Cylin...#ht_2118wt_948 For cars that are a pain to bleed this is a real lifesaver http://www.harborfreight.com/brake-f...der-92924.html This unit works so good when I did a complete brake job and dual master upgrade on my '54 Ford it was over 100+ outside and since I had a few PBR's to quench my thirst I forgot to bench bleed the master,so I hooked it up anyway and within 10 minutes total the system was all bled out and working great.
I think you're right! I see that master and the smaller Corvette booster on a lot of cars!
I have this HF vacuum bleeder, and I like it because it's simple. The pneumatic looks like it would be even easier using a air compressor to pull fluid through!
http://www.harborfreight.com/brake-b...kit-92474.html
