is it the brake booster?????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2010, 08:41 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Ok so it sounds like I have a vacuum leak but when I hold the brakes down it goes away.I've checked for a leak but can't Seem to find one&it seems to be coming from uner the dash of the drivers side.
Old 05-24-2010, 08:43 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Disconnect the vacuum line from the booster and plug it then see if the leak goes away.
Andy
Old 05-24-2010, 09:34 PM
to check booster wait till next day or next year , pull the check valve fitting the hose hooks too .
you hear swoosh , booster good .
i've seen them hold for years not running scrapping cars .
probably tour heater vacuum components .
diaphragm shut and opener .
mouse eat a hose under dash ? .
Old 05-24-2010, 09:58 PM
two cups of tea
Wiki Edits: 2
But if that is the problem Would tue leak go away when I hold the brakes down?
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
s10 brake booster haulinass-10 Suspension - Brakes - Steering 13 03-27-2009 06:57 PM
1997 blazer..Brake booster gone bad? RodFather Suspension - Brakes - Steering 2 06-17-2005 01:26 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
