There's a valve that seals the side of the booster nearest the pedal so there's vacuum on BOTH sides of the diaphragm when the brake pedal is not applied. This valve opens when the brake pedal is depressed, which allows atmospheric pressure to enter the pedal side of the booster, allowing the vacuum on the master cylinder side to help apply pressure to the MC. If this valve isn't sealing the pedal side when the brake pedal isn't depressed, the vacuum on the MC side of the diaphragm will pull the pedal downward. Here's an interactive representation of a vacuum operated power brake booster. Last edited by cobalt327; 09-27-2012 at 07:22 PM. |
What I would do is contact CPP via email directing your email to the owner, senior manager and manager of customer service and again explain your problem. Then explain how your problem and how its being handled by their company is currently being discussed on Hotrodders.com. Explain that the collective concensus is that there is a problem with their unit and perhaps the other members of this site might take their business elsewhere where their concerns are addressed better. Point out that after service is what brings customers back and word of mouth brings new customers in or keeps them away. Then explain that you probably talked to the wrong person the first time and ask who would be able to resolve this issue because you know they want to keep you as a happy returning customer. You might also point out that Hotrodders.com is the largest and busiest automotive website in the world.
Never hurts to try. |
Thanks much for the very much appreciated replies everyone.
I just had a gut feeling that the booster is causing this. I feel more convinced now. However, they did send me a different booster a few weeks ago,hesistantly, and it has the same issue. Now I guess you could assume that since both boosters have the same issue, that the problem lies elsewhere. OR, both boosters are at fault, as well as maybe countless others. Everything they sell has a lifetime warranty,and I will not talk harshly about any vendor but aggravate me enough and I will. When an overseas made product is faulty, the vendor won't tell you this. So it's hard to get customer satisfaction being that,that's the way it is. I feel that in all actuality, they should keep sending me these cheap overseas disposable boosters until I get a good one. Oops, starting to rant. I guess I was thinking of the advice they gave me, which was to relocate the pedal to booster push rod, on the pedal.Try drilling a different hole on the pedal. Maybe I need to change the angle of the pushrod. WHAT???? I bought a PREENGINEERED FULLY ASSEMBLED BRAKE ASSEMBLY KIT. I am under the assumption MBM boosters are USA made. I will probably just eliminate the source altogether and hopefully get lucky with MBM. Whatcha think? |
Too bad it can't be something easy...
Given the info you've provided and the checks you've made, if it's not the booster, I'm at a loss. It shouldn't cause the problem, but have you checked the vacuum check valve between the engine and the booster? |
If no useful help from CPP, I guess I will have to take a gamble and try a different booster from another source. If all else fails, hydroboost it. |
Install a second return spring. With the engine running depress the brake petal and release. If petal returns fully try a few more times. If that fixes the problem that's good. If not and the petal dose'nt return without touching the petal shut the engine down and have someone pull the check valve from the booster. If the petal returns to the proper position you've got a bad booster, if not you've got a possible restriction in the brake system. It might be the fluid is not returning compleatly to the master cvlinder. Something to try.
BB |
I hope by now, your brake problem is resolved. Try going to MBM website, it may help you to trouble-shoot problem. They are very helpful on the phone...1-800-231-4125, talk to sales. Good luck!
| 67 brake booster help | my52 | Suspension - Brakes - Steering | 3 | 03-01-2009 12:10 AM |
| Brake booster | kgbronco | Suspension - Brakes - Steering | 4 | 01-05-2009 07:45 AM |
| brake booster | jasrking | Suspension - Brakes - Steering | 2 | 10-26-2008 08:21 PM |
| brake booster | bb53f100 | Suspension - Brakes - Steering | 7 | 02-27-2004 02:13 PM |
| Brake Booster | mac | Suspension - Brakes - Steering | 3 | 06-26-2002 06:07 PM |
