Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake Booster Bracket
Old 05-13-2012, 06:18 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Originally Posted by cobalt327
I don't know if you looked over all the brackets, but there's quite a few to choose from.
Depending on the booster you want to use, the original bracket might work once it's removed from the old booster.
I was going through that same list and they're all close, but all different at the same time. The booster I have has the 4 studs in the same position as the stock on, but just need that adapter to have the right pattern on the firewall. I tried to get the stock one off, with no luck though. Is there a trick? It's the original booster that I pulled off, and everything is rusted into one piece.
