Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake Booster Bracket
Old 05-13-2012, 11:34 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Originally Posted by cobalt327
You might have to separate the vacuum chamber to access the inside back half of the booster to see what the bracket is held on with if there's no obvious fasteners seen on the outside. I have never done this- so I'm shooting from the hip here.
I had tried to. It looks like the front of the booster is supposed to rotate and then slide right out, but could not for the life of me get it to budge. So I tried taking a grinder to the 'lips' of what seems to be holding the 2 together. Sadly, even after doing that, and then pounding on it... had no luck.
I emailed Summit Racing with the same question and pics, see if they know exactly which one I need. They all look off!
