Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake Booster Bracket
Old 05-18-2012, 09:21 AM
1971BB427's Avatar
1971BB427 1971BB427 is offline
Did you bench bleed the brake master before installing it? If you did, then you can often avoid bleeding the whole system, but if your rakes are "soft" then you need to not only bleed the calipers, but the whole system now.
