Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake Booster Bracket
Old 05-18-2012, 10:28 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Originally Posted by 1971BB427
Did you bench bleed the brake master before installing it? If you did, then you can often avoid bleeding the whole system, but if your brakes are "soft" then you need to not only bleed the calipers, but the whole system now.
I'm going to assume I didn't considering I have no idea what bench bleeding is. Damnit. For future reference, got a link to how to do that?
