I agree. Check the location of the operating rod on the brake pedal attachment. Make ure if there are two holes that it's closest to the pivot point. Also check your vacuum connection, and your vacuum with a gauge to ensure you've got no leaks and a good connnection.
Follow up
Just got a follow up to this. I've adjusted the position of the pedal numerous times, tried playing with the master, and even tried adding a little extension on the push rods going into the master. I've got it pretty good, but it still requires a lot of force for the car to really stop. I can't get the rod in any further into the booster off the pedal, and the pushrod is right up on the plate in the master without the brakes dragging. I still can't slam on the brakes without using both feet.
Last option I have to try is to hook up the extra vac canister. Question is, does the canister and the booster hold more vac than the motor makes? For example, if motor is putting out -10, the booster/canister won't be over -10? And secondly, does it take time for the masters to "break-in"? Is it going to get "softer" with some miles? Only put about 4 miles on it so far, so still really new. Thanks. |
No, masters should be great right from the start, and not change as they age. If you only have 10" of vacuum that might be part of the issue. That's pretty minimal to run vacuum brake boosters.
Also, you should have a check valve in the booster vacuum line.
PatM |
You can also check the booster by pumping the brake pedal a few times w/the engine off, then while holding moderate pressure on the brake pedal, start the engine. The pedal should drop some.
Wanted to give the update here.
After reading all this and doing more research, it seemed to me the booster was bad. I drove it around and was always needing way too much pressure in order to get it to stop. Even after talking with other rodders at shows, they said the smaller booster will be more difficult, but shouldn't be as bad as mine was. Got in touch with the company I got the booster from and they said to send it back for an exchange. Finally got the new one and installed last night and it works great. Drove up the driveway and nearly went through the window. Stops on a dime! Takes very little pressure and the pedal feels like it should. Thanks to everyone for their help and suggestions. |
Brake booster bracket
Call Bud Riser at Tuff Stuff 800-331 6562. He can furnish you with a direct bolt on setup,chrome or plain.He is a good friend and has helped me out more than once over the years.Use my name if you like.
| Tags |
| booster, brake |
| brake caliper bracket | jaslong | Suspension - Brakes - Steering | 9 | 11-15-2008 07:22 PM |
| Emergency brake bracket on T-56 trans? | staleg | Transmission - Rearend | 0 | 08-11-2008 02:22 AM |
| any body know?versalle brake bracket ? | barnym17 | Suspension - Brakes - Steering | 6 | 03-29-2008 08:52 AM |
| Need Help with a brake booster and pedals bracket on firewall! | streetrodder31 | Suspension - Brakes - Steering | 13 | 02-26-2007 11:55 AM |
| brake bracket | bigvofnash | Suspension - Brakes - Steering | 0 | 09-12-2003 08:36 AM |
