Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake Booster - Hard to change?
Old 09-15-2004, 08:14 AM
advanced design's Avatar
advanced design advanced design is offline
Remember, this is to be fun!
Last journal entry: Lead Joint replacement
Welcome to the forum,
You should be able to unbolt the master cylinder from the brake booster and move it out of the way for booster removal without opening the brake lines. And if you have to remove the master cylinder from the brake lines not a big deal as you will then need to bleed the brakes.
As you go forward with projects a service manual for your Camaro will be a valuable aid so you might want to pick one up.
Good luck and have fun!
