Brake Booster Increase Idle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2012, 05:39 PM
I just replaced the booster in my '74 Chevy K10. The old one was not assisting at all and the engine would stall when I pressed the brakes. Bought a replacement at Autozone (Cardone) and now when I press the brakes the idle comes up a couple hundred RPMs then goes back down to normal. If I hold the brake pedal down, the idle will return to normal after a couple of seconds.
From looking at the service manual, it appears the booster has a valve that closes the rear chamber to vacuum when the pedal is pressed and only opens it back up to vacuum when the pedal is released. Brakes are working fine. So, is this "new" booster leaking as well? Thanks for the info.
Mike
Old 07-11-2012, 05:50 PM
LATECH's Avatar
Sure sounds like it has an issue. I would put on another one. I have never had a booster do that, but it aint right.
Fact is stranger than Fiction
Old 07-11-2012, 06:29 PM
T-bucket23's Avatar
Wiki Edits: 26
If it is a Cardone, it is most likely bad. Their parts are junk. Do yourself a favor and buy an oem or get one at the junk yard.
Chet
Old 07-11-2012, 09:57 PM
Did you install a new vacuum check valve?
Old 07-12-2012, 11:14 AM
I installed a new check valve with the booster.
I originally ordered an "AC Delco" from Rockauto. It had an AC Delco label on it, but it said "Re-manufactured for" on the box and the part was in the same box and had the same tags as the Cardone. I don't think you can get decent parts anymore I guess I'll be pulling it back out. Thanks guys.
brake booster jasrking Suspension - Brakes - Steering 2 10-26-2008 08:21 PM
Substantial idle increase with PCV unplugged 85CHEVY Engine 5 05-14-2007 12:33 PM
Brake Booster DAVIDTEDDYBEAR Suspension - Brakes - Steering 1 09-23-2006 03:22 PM
Brake Booster mac Suspension - Brakes - Steering 3 06-26-2002 06:07 PM
Brake booster mac Suspension - Brakes - Steering 3 06-26-2002 02:43 AM
