Brake booster issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2010, 10:56 AM
Brake booster issue
I just put a new brake booster on my 64 Chevy II. I had switched to disc brakes a year ago, and the booster went bad, so since it was still under warranty, Stainless Steel Brake Company sent me a new one. I installed it, and then took it for a test drive yesterday. The disc brakes in the front kept clamping down as vaccumm built up in the booster, as if the booster is putting way to much pressure into the system. How do I fix this problem? Is there some way to adjust the booster? I tried to adjust it in the front of the booster, where it bolts to the master cylinder, but it didnt seem to do much, if any good. Help!
Old 11-02-2010, 11:31 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
You need to adjust where the brake pedal linkage goes into the booster . You have to have a little free pedal as well as making sure that there is clearance between the booster and master cylinder . Both of these areas MUST have a little free travel. Not much mind you . 1/16" to 1/8" is plenty .
Old 11-02-2010, 01:06 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Although adantessr is correct about some play it needs to be between the peddle and the booster.
Do you remember how many turns you moved that adjustment, just go back that amount. The distance from the booster too the MC should just be not touching.
You describe a situation as if you were ridding the brake peddle, so that is where you need the play.
Old 11-02-2010, 03:54 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
That's what I was trying to say , but I guess I didn't articulate it correctly. QUOTE : You need to adjust where the brake pedal linkage goes into the booster . You have to have a little free pedal .
Old 11-02-2010, 04:22 PM
I did adjust between the pedal and the booster, and I still had the same problem a few blocks down the road. My brakes were smokin! I pulled over and made more adjustment, and pulled the vaccumm out of the booster, replaced it, and made it home - a little better, but the car doesnt roll like it should , and it still feels as though im riding the brakes when I am not. I will adjust it some more and test it out again.
Old 11-02-2010, 04:31 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
I'd verify that you do have a little clearance between the booster and the master cylinder and if all checks out you may very well have a bad booster . Did the brakes release when you disconnected the vaccuum hose ? You might take it just around the block with the hose disconnected and plugged . Don't go too fast 'cause you will have to stand on the brakes to stop .
Old 11-03-2010, 08:05 AM
pepi's Avatar
Originally Posted by adantessr
That's what I was trying to say , but I guess I didn't articulate it correctly. .
very astute thank you.
I would think that the rear brakes would be affected also.
Here is a references that can help you solve the problem; talks about dragging brakes.
http://www.mpbrakes.com/technical-su...ng-disc-04.cfm
Old 11-03-2010, 11:32 AM
Thank you everyone. It was the booster pin. I shimmed the master cylinder awy from the booster, and the car rolled much better, so I turned in the booster pin, and the brakes are working just like they should now!
Old 11-03-2010, 11:47 AM
pepi's Avatar
Killer .... did the MP link help you on that?
Old 11-03-2010, 12:28 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
I am glad you got it taken care of. I'll bet that the next time you replace a booster or a master cyl for that matter you'll think to check before bolting it up . The reason it showed up in the front more than the rear is because the disc brakes don't have any free travel . Back to post #2 .
Old 11-03-2010, 07:57 PM
I had already figured it out by the time the link was posted, but that link confirmed that I had the problem I thought I had. Thank you.
Settle a Brake Issue Doubleclutch Suspension - Brakes - Steering 6 07-31-2014 09:12 AM
Brake Booster vs. 351W - HELP!!! Fairlane351 Engine 18 04-19-2010 10:48 AM
Questions about master cylinder and brake booster mike69 Suspension - Brakes - Steering 1 08-15-2009 09:42 AM
Brake Booster F150fatman Suspension - Brakes - Steering 2 07-21-2007 04:32 PM
Brake Booster - Hard to change? RapidRoy Suspension - Brakes - Steering 2 09-15-2004 08:19 AM
