I am having trouble figuring out what brake booster my dad put on the 1937 international D series street rod. I have completely struck out at the local parts shops. I am hoping someone can help. I do believe the master cylinder is possibly off a Mustang 2. The truck has a Mustang 2 front end. Thanks in advance for any help!
That appears to be an early Fox body Mustang booster and master cylinder, as in early 80s style. Mustang II booster had a non-symmetrical bolt pattern, the lower left bolt was offset up more than the right side.
How much difference would there between the 2 boosters, from Mustang 2 And S-10? i used S-10 boosters and M/Cs on my 49 ford convert [S-10 front clip] and S-10 boosters on the 50 merc and the 49 ford convert both , one has ford 9" and the 50 Merc has a Nova rear. bob s
ps diamaters and proportioning valves worked well with Nova and ford
If it was me, I would use the dual diaphragm Mustang booster, NAPA pn NBB 5473207. If you want to use the S10 master cylinder, I believe you have to file the mounting holes to make it fit over the studs, and possibly readjust the pushrod.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
