Brake Booster not Lining Up - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2013, 06:49 PM
I have a 7" single diaphragm brake booster single which is being replaced by a 7" dual diaphragm booster. When I placed the new booster in position I found that the master cylinder is not sitting at right angle to the front mounting bolts. It is about 15 degrees askew. I notice when comparing both boosters that the original one seems to have been turned slightly (outside shell) more when it was assembled. How could I rotate the outer shell of the new booster about 3/16" so that the master sits level?
Brake booster? bigj7698 Engine 1 03-25-2012 08:34 PM
mustang rear brake lining replacement WCL Garage - Tools 3 12-22-2010 04:25 PM
brake lining wrench cares Garage - Tools 5 04-22-2007 08:03 PM
Brake booster M&M Suspension - Brakes - Steering 5 03-31-2006 02:56 PM
brake booster 34Plymouth Suspension - Brakes - Steering 3 02-14-2002 09:53 PM
