Brake booster pushrod adjust - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2012, 07:20 PM
How do i adjust the brake booster pushrod?? Have tried everythng else to get brakes!!
Old 02-19-2012, 03:09 AM
brake booster push rod adjustment
Is it the push rod between the booster and the master cylinder you are trying to adjust ?
Old 02-27-2012, 07:40 AM
Last journal entry: Still running strong
Make an adjustable push rod by cutting rod an threading rod.Use one of the long nuts like the ones you find on eye bolts. And 2 lock nuts on each end of the long nut.
Old 02-27-2012, 08:54 AM
this shows how to do it http://www.classicperform.com/TechBo...ot.htm#pushrod
The tool part number is CP2003
Old 02-27-2012, 04:13 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Easy adjustment but critical to get it right. Crawl under the dash and turn the rod 'til it feels like it has just hit the plunger in the MC. Now turn it 1/2 turn at a time and pump the brake pedal (engine running) to get a feel for whether it is working. There is a very narrow band of adjustment where the thing works properly. A turn too far in and the brakes lock up. A turn too few and you have no pedal and virtually no brakes. Sensitive but pretty easy to get right before you get a cramp in your side from your awkward position under the dash!
79 Firebird rear disc emergency brake adjust retiredusncustoms Suspension - Brakes - Steering 6 01-18-2011 01:06 PM
Brake pushrod question impalaman63 Suspension - Brakes - Steering 4 07-06-2010 06:19 AM
Adjustable pushrod for brake master cylinder, from booster grobb284 Suspension - Brakes - Steering 6 02-18-2010 08:42 AM
67 brake booster help my52 Suspension - Brakes - Steering 3 03-01-2009 01:10 AM
One more time, 40 Ford brake adjust?? CamSweet Suspension - Brakes - Steering 2 04-08-2007 12:33 PM
