Brake booster question for a 1963 Impala - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2010, 09:07 AM
impalaman63's Avatar
I have a 1963 Impala with drum brakes all the way around. I want to install a dual power brake booster . The car has a stock 283. What size dual booster will fit without hitting the valve covers? 7-7.5-8-9-11 I have a dual master cyl. from a 1967 Impala all ready installed so all I need is the booster. I see Power brake boosters require 16 inches of vacuum.
Old 11-03-2010, 10:11 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
283 should have the vacuum needed, is there a special reason you wish to use the dual booster. The dual booster is longer how about the single model have you considered that?
I can not remember did the 63s have power brakes, if so look for the stock size made for that year as a guide.
Those folks at MP are pretty sharp and freely give advice.
Old 11-03-2010, 11:21 AM
poncho62's Avatar
Wiki Edits: 5
My 62 had power brakes, so a 63 PB booster is available.......Now, just find a dual chamber master cylinder that will bolt to it.
Old 11-11-2010, 09:45 AM
Been doing some research on many sites.
Sounds like the Cardone brake boosters are JUNK (stock replacements 54-73537).
I need to look into a aftermarket type brake booster. Would a 8" Single Diaphragm Brake Booster be big enough or should I go with a 9"?
Will a 9" fit?
I have drum brakes on all 4 wheels and a dual master cyl. now.
Thanks
Old 11-11-2010, 12:30 PM
I found out my Dual master cyl. has a 1 1/8" bore will this work with a 8" or 9" brake booster or should I get a 1" bore dual master cyl?
Thanks
Old 11-11-2010, 04:15 PM
Correction
I just got a email from Cardone saying my master cylinder is a 1" bore NOT a 1 1/8' bore.
1963 Impala single Master Cyl. to Dual MC? impalaman63 Suspension - Brakes - Steering 6 06-24-2010 05:13 PM
brake booster size pigjamelectric Suspension - Brakes - Steering 3 05-08-2005 09:44 PM
Minus the brake booster?? dpjmw Suspension - Brakes - Steering 4 03-17-2005 12:20 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 07:17 AM
Power brake booster hissing jrm123180 Suspension - Brakes - Steering 2 03-19-2004 09:59 PM
