Brake booster relocation. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2006, 04:07 AM
Hi all.
I'm currently building a 63 EH Ute and would love to move the brake booster out of the bay and into the try somewhere. I have seen it done but have no idea on where to start or anything.
Any help would be greatly appreciated.
Thanx
Derek
Old 06-16-2006, 08:11 PM
A lot of rodders here stateside have used the kits from the street rod shops that mount a power brake booster and the pedal below the floor board.
Not having seen a 63 Ute ... I do not know if that might work for you ..
Old 06-16-2006, 08:57 PM
Yeah not sure if that will work unfortunately. It's a Monocoque( something like that) body style so no chassis rails to mount to or keep protected by if you know what I mean.
What I was thinking about doing, have been awake most of the night thinking of ideas is to mount the master cylinder under the guard and then run lines to under neath the rear ray area(massive amount of room) and mount the booster there. I just not sure if I need any one way valves or any of that stuff to be able to do it safely.
I am of the belief that an engine is for an engine and nothing else should be seen in there. Hence I'm going to have real fun completely rewiring the motor so that all the wiring is hidden.
Cheers
Derek
P.S. Piccy is not of my Ute unfortunately but gives you an idea of what they look like.
Old 06-16-2006, 09:42 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
mid 70's dodge/chry full size vans use a set up that had the MS setting at a 90* angle. if u can't find one of those Kugal has this
now other companies my sell them but this the only one i have found...joe
Old 06-16-2006, 09:51 PM
That is awesome Thankyou hugely that should do exactly what I want and fit as well which always helps.
Just have to check the legality of it with my engineer.
HUGE thanx
Derek
Old 06-16-2006, 10:24 PM
Wiki Edits: 5
HUGE thanx
Derek
heck if the Chry Corp used basicly this same set up in the 70's vans it should be good to go...joe
Old 06-16-2006, 10:28 PM
Yeah should be alright BUT I live ina state full of crappy laws and regulations about car mods, Just another question to ask him when I eventually get him over.
Old 06-20-2006, 12:46 AM
Gr8 '48 bow tie's Avatar
Be American, Buy American!
[QUOTE=V6EHUTE]Yeah not sure if that will work unfortunately. It's a Monocoque( something like that) body style so no chassis rails to mount to or keep protected by if you know what I mean.
Cheers
Derek
If you are concerned about the safety of the Ute because of the unibody, have you thought about the possibility of sitting the Ute on a S10 0r S15 chassis. I don't know the dimensions of the Ute but looking at the pic makes me think they are about the same. If that is in fact true, (I have not put a great deal of thought into the project, it may work and it may not work) possibly six or eight U-bolts might just saddle the Ute onto the S10 chassis. You could call it a Utes10 (sounds like you testin to see if it will workout for you). It would raise the Ute at least 6 to 8 inches. Just a thought.
Al[/U]
Old 06-20-2006, 02:25 AM
Yeah that's an idea but rasing it by 6 or 8 inches NOOOOOOOO
LOL
I want to slam it on the ground Am making a full chassis rails for it so that should make it nice and strong, they are already pretty strong being made in 63 they built them tough as anything. But a little bit extra can't hurt.
Hmmm Like the name though what about EH-S10.
The under dash Booster looks like a winner at the moment Unfortunately I'm linited by space under the dash but there should be enough for one of those. The aircon is going in the tray under the parcel shelf and will be hidden by a false wall so should do the trick.
Thanx
Derek
Old 06-20-2006, 03:47 AM
staleg's Avatar
Last journal entry: Hand brake
It is nearly the same setup as in a little Toyota truck with bulldog nose called Dyna. The car is not sold in the US as far as I know, but maybe in Australia.
1997 blazer..Brake booster gone bad? RodFather Suspension - Brakes - Steering 2 06-17-2005 02:26 PM
brake booster size pigjamelectric Suspension - Brakes - Steering 3 05-08-2005 09:44 PM
Booster Relocation Kit ALASKAN Suspension - Brakes - Steering 6 12-07-2004 08:06 PM
Power brake booster hissing jrm123180 Suspension - Brakes - Steering 2 03-19-2004 09:59 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
