brake booster size - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2005, 04:29 PM
pigjamelectric's Avatar
oldsmobile compatible
Last wiki edit: Selling your car Last photo:
Wiki Edits: 29
brake booster dilemma
I searched the archives, but didn't find anything on this one:
I'm getting an 1980 Dodge pick-up ready for restoration. I've stripped a bunch of parts off an 1986 Dodge to use on the '80.
The brake booster on the '80 (left) is large circumference but narrow profile, and the booster on the '86 (right) is the opposite. Is one of these booster models superior to the other? I don't know if this is a case of newer is better or if a booster is a booster is a booster.
Any input is appreciated. Thanks.
Old 05-08-2005, 12:39 PM
I would use the newer one in aluminum.
Old 05-08-2005, 04:29 PM
302 Z28's Avatar
No, a booster is not a booster, there are difference's. Go take a visit to the Master Power Brakes website, they have a lot of information on brakes.
Vince
Old 05-08-2005, 08:44 PM
Wiki Edits: 29
Thanks for the reply. I visited that web site and it had a lot of information as you said.
I have been doing some more research and have found that there are two types of Mopar big blocks: the RB type (= raised block; anything bigger than a 400) and the B type (400 and under).
Installing a RB block would require the smaller diameter brake booster to accommodate the valve covers. I'll put in the newer booster, but with gas prices as they are, I don't think I'll be shopping for a RB block anytime soon.
Paul (slowly mutating into mopar compatible )
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
69 Pontiac Brake Booster Problem.. jboy Suspension - Brakes - Steering 8 07-22-2004 10:59 AM
Power brake booster hissing jrm123180 Suspension - Brakes - Steering 2 03-19-2004 08:59 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
Delco Moraine Brake Booster Check Valve 454impala69 Suspension - Brakes - Steering 1 02-25-2002 04:07 AM
