Brake Booster Trouble.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2010, 03:40 PM
I'm having this weird problem with my new brake booster. It makes a weird creaking sound when the brakes are applied. It also is a little sticky.
It is defiantly not the pedal linkage.. When I disconnect the clevis, the pedal swings just fine..
My Poncho has a big cam, I wonder if it's the gas fumes getting into the rubber diaphragm. The old booster did the same thing...
This one has me stumped. I'm ready to remove the booster all together and run manual brakes.. I already have the 6:1 manual brake pedal installed due to low vacuum..
Any thoughts?
Thanks..
Checkout the videos..
http://www.youtube.com/watch?v=JvPzQ-lbENU
http://www.youtube.com/watch?v=mmgJFynqfCI
Old 10-11-2010, 04:37 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I have heard that before, It's where the plunger is working through to the booster. Don't know exactly how to explain it but i think it is the rubber inside between the rubber and the vacuum and the push-rod when pushing the pedal down. JMO but a combination of these things causes it to make this sound sometimes. JMO.
Wish i had a better explanation. Maybe someone else can explain it better.
If you have a very large cam then maybe you need to do something different
Either go manual or add something for vacuum to help it out. Possibly a lack of vacuum causing the problem.
Cole
Old 10-11-2010, 04:49 PM
eloc431962's Avatar
Wiki Edits: 37
I went with a manual disc set-up on my camaro and i love it good pedal and stopping.
Cole
Old 10-11-2010, 04:59 PM
Thanks for the info Cole..
I have a 1" bore 74 Vette master now, it was for the manual brake vettes. I've heard of guys going even smaller in bore with manual brakes.
Do you remember what size bore master cyl you used on your Camaro?
I've heard a lot of good things about the manual brake disc/drum set ups..
Old 10-11-2010, 05:00 PM
The creaking crunching noise may be due to the brake fluid being old as this was a common problem on older ford windstars and mazda has a recall for this problem. remove the old fluid from the master cylinder resevoir and run new fluid thru the system. hopefully that will fix it for you, good luck
Bob
Old 10-12-2010, 04:40 PM
eloc431962's Avatar
Wiki Edits: 37
Sorry Pitts' i can't remember the bore size but if i get a chance i will pull it and check and post for you if you don't already know.
Cole
Brake Booster F150fatman Suspension - Brakes - Steering 2 07-21-2007 05:32 PM
pwr brake booster issues? Dgas Suspension - Brakes - Steering 6 06-19-2007 11:20 AM
66 Chevy brake booster help? badriand Suspension - Brakes - Steering 1 06-03-2007 03:01 PM
1997 blazer..Brake booster gone bad? RodFather Suspension - Brakes - Steering 2 06-17-2005 02:26 PM
brake booster size pigjamelectric Suspension - Brakes - Steering 3 05-08-2005 09:44 PM
