Brake Booster Vacuum Connection - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2010, 09:51 AM
david-b's Avatar
Dave is THAT guy
Hey all.
Was looking at my brake booster and where the hose comes from. It looks like in pics that there's a piece coming out from the hole which then connects to the hose. I just have a rubber grommet on it. Does that connector have a name or is it anything special? I don't see any threading inside the booster, so does it just pop in? Any help is appreciated. Thanks
Old 11-11-2010, 10:15 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I think you may be referring to the power brake booster check valve.
The check valve (shown below) is the plastic part that plugs into a rubber grommet on the booster itself. You can get one from any auto parts store, <$10.00. I believe I've seen them on the "HELP" parts asile. A Delco part would be preferred, IMO.
The booster needs to be supplied by manifold vacuum, and needs to be a large line- (~3/8" ID?) and not the 1/8" vacuum lines like used for vacuum advance, etc.
Old 11-11-2010, 10:18 AM
david-b's Avatar
Dave is THAT guy
Nice nice. Thanks. Is this available at my local auto parts store?
Old 11-12-2010, 12:25 PM
FastOrange's Avatar
Yes...
Brake booster issue hcmill66ss Suspension - Brakes - Steering 10 11-03-2010 07:57 PM
running no vacuum advance oregon chevelle Engine 28 02-07-2007 07:17 PM
No ported vaccum port in my Q-jet, help Augusto Engine 11 12-27-2006 05:04 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
brake booster vacuum problem spankthru Engine 1 06-18-2003 07:57 PM
