Brake booster vacuum leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2008, 10:31 PM
70 ElCam's Avatar
Rebel with a Chevy
Hello all . I have run a search on here for related threads and didn't come up with anything on this particular seal. I have a complete power brake system off of a 71 Monte Carlo swapped on to my 69 Chevelle . Recently a vacuum leak has developed in the booster to master cylinder seal . That is the seal that goes on the booster rod in between the MC and Booster. Where can I locate one of these seals . I put a band aid on it for the time being and put black RTV on the MC mounting flange . It works fine for now with no more leaks, but I want a new seal if I can get one. Anyone bought this in the past? Thanks.
Old 10-10-2008, 07:09 AM
Shelby1's Avatar
Steel Dreams
If memory serves me right I don't think you can buy individual parts for a vacuum booster unless you can find a booster rebuild shop that are willing to sell you the parts you need.That beening said ,if you have a leak where you say it is leaking you could have a diaphragm that has a hole in it as I seem to remember that seal is part of the diaphragm and has to be rebuilt to fix it ,or replace the booster it self.Check with your local parts stores for prices vs a rebuilder that you can deal with directly.I work on a fleet of medium duty trucks and we have ours rebuilt tru a local rebuilder ,close to 200 buck diff it price. Hope this helps,good luck.
Kenny
Lost your job yet?
Keep buying foreign.
Old 10-10-2008, 11:16 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Please just replace the booster...
Old 10-12-2008, 10:58 PM
70 ElCam's Avatar
Rebel with a Chevy
My diaphram isn't holie!! LOL .
No, seriously. I've rebuilt several boosters before with great success. Only problem now is that my connection for the diaphram and seals no longer exists . There is a seal in between the MC and the booster that slips over the brake rod that has a split seal on it that is leaking on my car. I have had the booster apart and everything checks out inside it, A OK. Just the split seal around the booster rod is showing fatigue .
I put nearly 500 miles on it this weekend at " Cruising the Coast " in Biloxi/Gulfport MS. with no problems whatsoever after I sealed the MC to the booster. I'll try to find a schematic /breakdown of this particular set-up that shows what is needed. Thanks for the feedback.
Kevin
Old 10-12-2008, 11:04 PM
70 ElCam's Avatar
Rebel with a Chevy
Originally Posted by Shelby1
Kenny
Lost your job yet?
Kenny,
I'm with you on that . I work for Delphi Automotive Systems , which used to be GM . How I know all of this........
Delphi is only the "worlds" largest automotive supplier . Are you getting the picture?
Old 10-12-2008, 11:12 PM
70 ElCam's Avatar
Rebel with a Chevy
I don't work like that. If it ain't broke , don't fix it. My booster is fine . Why replace the booster because of a $3.00 split seal gone bad ? that's like replacing a transmission with a dipstick tube leak .
Old 10-13-2008, 12:04 AM
powerrodsmike's Avatar
Wiki Edits: 161
Try these guys for parts..
http://www.power-brake-exchange.com/
Later, mikey
BE different....ACT normal.
Old 11-08-2009, 07:52 PM
Brake booster front seal
Has anyone located a source for a front booster seal for 70's GM power brake booster?
Old 11-08-2009, 08:52 PM
70 ElCam's Avatar
Rebel with a Chevy
Yes, I can get the seal . I need a number or the seal to match up with. A local brake re builder has these in stock.
Old 11-09-2009, 05:36 PM
Booster Seal Part Number
Number on the seal is Bendix 2500932 Approximate dimensions 1.56 OD, .43 ID, .25 THK
Old 11-09-2009, 06:20 PM
Wiki Edits: 161
Please take this current discussion into the PM's guys.
Later, mikey
Old 10-03-2010, 11:30 PM
New Member
i having the same issues, i just want to ask if there are alternative fixes other than replacing the complete booster? Ive seen a couple of How to Replace a Brake Booster discussions and some say replacing individual parts is possible.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Vacuum adv.. underdog305 Engine 58 01-30-2007 11:19 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
At witts end with vacuum leak!! HotRodMan Engine 7 12-17-2003 08:41 PM
brake booster vacuum problem spankthru Engine 1 06-18-2003 07:57 PM
