Brake booster vacuum leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2013, 12:58 PM
I had to remove power brake booster and master cylinder on 76 K 5 Blazer, to cut and rebuild brake pedal to go around new ign. switch and other things on tilt wheel etc: After finding pedal now hit floorboard before brakes worked I cut pedal and fixed that problem. Brakes seem to work fine now but when I have no pressure on the brake pedal I hear what sounds like a vacuum leak from inside firewall around brake booster. If I just lightly touch the pedal the noise goes away. I havn't put the brake light switch back under there. Would mounting that so there's a lil pressure on the pedal be the answer? Don't see any leaks around vacuum line on front of booster. Disc on front drums on back. First time on forum and beginner hot rodder.im 60'years old and was into in the 60s but forgot most of it now.
Old 03-22-2013, 06:47 AM
Last journal entry: Still running strong
You don't want that brake light sw. to be putting any pressure on the brake pedal. The break pedal needs to return all the way back to it resting position. The brake light button is the only thing that should be touching the pedal.
Old 03-22-2013, 09:00 AM
Uh, help me understand...
Tilt wheel, power brakes, etc were all factory available on the 76 full size trucks. Why are you having to cut and weld anything? This should be a total bolt-in.
Brake vacuum booster ? StreetKruzer Suspension - Brakes - Steering 1 04-14-2012 07:45 PM
Brake Booster Vacuum Connection david-b Engine 3 11-12-2010 12:25 PM
Brake booster vacuum leak 70 ElCam Suspension - Brakes - Steering 11 10-03-2010 11:30 PM
brake booster vacuum problem spankthru Engine 1 06-18-2003 07:57 PM
vacuum brake booster 48Man Suspension - Brakes - Steering 1 01-14-2003 06:10 AM
