Brake Boosters - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2006, 01:00 PM
__409__'s Avatar
'58 Chevrolet Belair
Brake Boosters
I have read about single and dual brake boosters, but they don't
talk about the difference in them, or the advantage\disadvantage of one over the other. I could you some help
Thanks
Old 04-09-2006, 02:34 PM
Dual boosters? or Dual chamber master cylinder?...Cheers!
Old 04-09-2006, 02:35 PM
powerrodsmike's Avatar
Wiki Edits: 161
single boosters have 1 diaphragm, require a large diameter booster to generate a large force. A dual diaphragm unit with a comparable boosting force has a smaller overall diameter, but is longer than a single. The pros to a single is that it will fit closer to the firewall if that is where the available room is, and they are a little more efficient. The pros for the longer dual is that it will fit under the floor on a vehicle with a frame mounted master cylinder, or clear the valve cover in a tight engine compartment.
master power brakes has a cool info section on their website. Here is one of the pages that might help.
http://www.911brakes.com/midsizebooster.htm
here is the rest of that web page ,you may find it useful someday
hope this helps, mikey
BE different....ACT normal.
Old 04-09-2006, 05:33 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Thanks
powerrodsmike has done a good job of explaining. The only thing I might add is to explain that it is all about square inches of area of the diaphragm. A larger diameter diaphragm will apply more pressure to the master than a smaller diameter diaphragm because it has more area acted on by the manifold vacuum of the motor. (Actually, it is the atmospheric pressure behind the diaphragm that moves it in the absence of pressure on the front of it as a result of negative pressure from the intake manifold). For instance, a 7" diaphragm will have 21.99 square inches of area, while an 8" diaphragm will have 25.13 square inches of area and a dual 8", such as needed for a disc/disc system will have over 50 square inches of area.
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
Annular boosters - the real deal or marketing hype? Mad Maggot Engine 18 11-22-2009 03:13 PM
Brake boosters, Does size make a difference? blacklotus Suspension - Brakes - Steering 11 01-27-2006 11:33 AM
Brake boosters crzytchr Introduce Yourself 10 11-23-2004 07:43 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
