brake boosters - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2006, 03:24 PM
brake boosters
I installed frt. disc brakes on my 40 ford and left drums on the rear. I did not install a brake booster but did install a proporting valve and a pressure valve cause the master cyl is below the frame. the question is is it ok to run w/o the booster I don't like touchy brakes?
Old 06-13-2006, 03:33 PM
50 chevy p/u's Avatar
autoglass master tech
Yah, It's ok to not use one.
There will be extra effort involved to stop, but you should be fine.
Power Brake Boosters 57halfton Suspension - Brakes - Steering 7 05-27-2006 09:37 AM
Brake Boosters __409__ Suspension - Brakes - Steering 3 04-09-2006 05:33 PM
Brake boosters, Does size make a difference? blacklotus Suspension - Brakes - Steering 11 01-27-2006 11:33 AM
Brake boosters crzytchr Introduce Yourself 10 11-23-2004 07:43 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
