Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - brake changing
Thread: brake changing
Old 08-17-2002, 11:36 PM
aka Duke of URL
Be advised that the rear piston must be (turned) back into the caliper with a special service tool as it is on a ratchet for proper hand brake operation. You try to press it back in with a c-clamp and the ratcheting mechanism will be damaged costing big bucks.
You also have the option of buying rebuilt loaded calipers and they would just be a bolt on (but requires system bleeding).
You first to need to find factual repair information (shop/repair manual) and go from there.
