-   -   brake/clutch pedals on '39 Ford (http://www.hotrodders.com/forum/brake-clutch-pedals-39-ford-55445.html)
sandman351 01-04-2005 08:29 PM
Can I adapt a brake booster and master cylinder for the brakes, and a master cylinder for a hydraulic clutch onto the factory clutch and brake pedal on my '39 Ford? Currently I do not have the pedals, so I would have to ebay/salvage yard find a set.
Any thoughts? I'd like to keep everything under the floor if I could.
Thanks!
Pat
302 Z28 01-04-2005 09:21 PM
Various firms offer the setup you are asking about. Personally I would not go the junk yard route on this, as it is going to be hard to find a car with an under floor setup. Download the Master Power Brakes catalog (pdf file) and look at the setups they have to get some ideas.
www.mpbrakes.com
Vince
OneMoreTime 01-04-2005 09:44 PM
pedals
Several of the resto rod suppliers have these available and the pedals match the originals..Comes as kit or the pieces that you will need to do this..:thumbup:
Might try Speedway motors or some of the others...maybe a better bet than trying to piece together a system..
they do provide them with the power brake booster as well if you desire..
Just taking the easy way out..:P
OMT
