brake connections won't seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2006, 07:48 PM
Put a complete new brake system (master cyl and stainless) on my 68 GS Buick. After bleeding brakes, leaks ocurred at the front brake hose connection and proportion valve connections. Using dot 5. Any recommendations? Thanks Frank
Old 11-25-2006, 08:23 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Did you double flare your lines yourself or did they come double flared?
Old 11-25-2006, 08:36 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
I would almost guess they are single flared. I have seen that posted before on other forums. Henry is correct in that they need the double flare.
Old 11-25-2006, 08:55 PM
brakes
Now not to be stupid, but how do I tell,single or double? Or am I stupid? Frank
Old 11-26-2006, 01:56 AM
If you did them you would know if you did them double flare. If you bought them already done then most likely they are double flare.
To do a double flare you first make a bulge (with the little black things in the pic below) in the line and then you flare it. You end up with a fold at the outside part of the flare and the end of the tube on the inside.
Old 11-26-2006, 11:33 AM
brakes
The brake lines are double flared from The Right Stuff. I'm going to take it all apart and start over again. Thanks for your help. Frank
Old 11-26-2006, 02:10 PM
T-bucket23's Avatar
Wiki Edits: 26
Probably bad flares. Overtightening wll generally only make it worse. Any reputable auto shop can flare a line for you
Old 11-26-2006, 02:46 PM
leaks
Thanks T. After a very FRUSTRATING day I decided to load it up a take it to a brake shop or the bone yard. Frank
Old 11-26-2006, 03:03 PM
Lost in the 60's
Wiki Edits: 4
The double flares are somewhat more difficult to make properly than single flares. You could have a couple of bad flares. Overtightening will cause leaks also...I general just snug my brake lines and then just gradually tughten untill they seal...kinda got to sneak up on them, Lmao. Anyway good luck.
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
rear oil seal help alrobjr Engine 5 01-24-2006 07:12 AM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 08:58 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
