brake conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2008, 11:52 PM
brake conversion
I have a question for anyone out there that can help me. I have a 67 satellite that i want to convert to disk brakes, and iam wondering what year and make of car i can find compatible parts on. also I have a 440 with a 727 trany to drop into it other than changeing the torsion bars what else may be required for the change over
Old 07-19-2008, 07:36 AM
poncho62's Avatar
Wiki Edits: 5
moving to brakes-suspension forum.
Old 07-19-2008, 09:20 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Look for a 72-73 Mid size car with discs.
If the potential donor car and your Satellite use the same lower ball joint,
you will be able to swap spindles and brakes----possibly even the upper control arms.
Get the master and booster from the donor car as well, AND the distribution block.
As for the torsion bars-----just tighten 'em up to get the correct ride height.
Not real sure if this will work----BUT----in the early 80s I swapped 73 Fury spindles / ball joints/ discs to my 67 Chrys 300 with factory Discs.
The ball joints and the rotors for that car in the early 80s was over $100 each piece. The 4-piston BUDD calipers were not available and mine were not rebuildable for the 1980 dollars that I was earning at the time.
The 73 Ply used the same ball joints as the drum equipped Chryslers of 67.
$20 rotors and $15 ball joints AND calipers that could be found anywhere----and bolt in and go
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 05:52 PM
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 06:15 AM
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 10:06 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 07:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
