Brake conversion 1965 gmc - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2010, 07:34 PM
imperial's Avatar
Crown Lover
Last journal entry: My little helper!
Anyone can tell me what year truck I can get front disks off of? Want to stay 6 lug if possible. Doesn't have to though. Can most of it be a bolt in deal? Anything you can tell me will be appreciated very much. Have searched on here.May not of typed the right thing for any answers.Still learning computer skills.THANKS
Old 01-03-2010, 11:06 PM
1971-87 gm trucks 1/2ton 2wd . as for staying 6 lug now that could make it more difficult. One might be able to use 88 newer rotors off of a 1/2 ton 4x4 gm truck. Not sure what you would have to do for backing plates or calipers though.
Old 01-04-2010, 05:48 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Yep----71-87 pickups
most everything is interchangeable, but you are stuck with 5-hole wheels
unless you want to go with an aftermarket rotor.
Classic Performance Products sell the rotor I believe.
I'm gonna be doing the same thing to a 64 C-10 very soon
Old 01-04-2010, 06:00 AM
70455's Avatar
67-72 would be the best choice for parts. As far as 73-87 would mean going to 5 lug which means you would run into problems with the rear end.
Old 01-06-2010, 07:10 PM
imperial's Avatar
Crown Lover
Thanks for the replies. Going to look for some donors trucks. Will put pics as soon as I can.
Old 01-06-2010, 08:27 PM
Bryan59EC's Avatar
I believe 71 was the first year for discs on the pickups.
71 would also be the first year for 5-hole wheels. (4x4 retained 6 holes into the 90s)
67-70----no disc brakes-----all were 6 hole drums
Old 01-06-2010, 10:11 PM
SSedan64's Avatar
Good Info on this site. >> http://67-72chevytrucks.com/vboard/s...d.php?t=363769
Old 01-07-2010, 12:54 PM
Yea to bad the site above me is to "political".....Would much rather stay HERE on Hotrodders.com........ Oh one other thing. say you do use 73-87 stuff to swap it. You will want to grab the outer tie rod ends as well off of the donor as the taper is different.
fairlane disk brake conversion 53belair Suspension - Brakes - Steering 6 02-20-2008 07:33 PM
Disc brake conversion kit Nichols6 Suspension - Brakes - Steering 3 11-22-2007 11:01 PM
Corvair Disc Brake Conversion tcruise Suspension - Brakes - Steering 3 08-31-2005 12:16 AM
64 el camino brake conversion camino_man Suspension - Brakes - Steering 0 01-30-2004 06:01 PM
Disc brake conversion for a 67' mustang Pencilneck314 Suspension - Brakes - Steering 6 12-07-2003 02:24 PM
