Brake conversion kit for 1950 Plymouth coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2012, 09:35 PM
Rulah's Avatar
Hi there anyone knows where I could purchase a brake conversion kit for a 1950 Plymouth 3 window coupe. Thanks for all the help
Old 04-22-2012, 08:34 AM
Wiki Edits: 27
more searching
My son has a 36 Plymouth there has been quite a few discussions in the past here on HR, do a search for brakes listing the various years of your body style and you should find quite a few
Old 04-22-2012, 03:12 PM
BOBCRMAN@aol.com's Avatar
Fatman Fabrications have front end kits for old Mopar.
Old 04-22-2012, 04:25 PM
Wiki Edits: 27
ball joint suspension.
I think there are kits to just add discs to your existing ball joint suspension.
Old 04-22-2012, 09:33 PM
hkestes's Avatar
48 Plymouth Club Coupe
I am using the kit from RustyHope on my 48 Plymouth coupe. Uses Volare rotors and S10 calipers. Other than drilling/tapping the three spindle mounting holes to a slightly larger size it is a direct bolt on.
Old 04-23-2012, 07:31 AM
RWENUTS's Avatar
Give these guys a try.
http://www.scarebird.com/
Old 04-23-2012, 07:25 PM
Rulah's Avatar
Thanks I will , what's the price on the conversion kit ?
Old 04-23-2012, 08:55 PM
rustyhope.com can help you out. Disc brake conversions for the old Mopars, and terrific technical assistance should you have any questions or problems. Check him out before you purchase a conversion kit. You'll be glad you did.
Old 04-23-2012, 10:31 PM
Rulah's Avatar
Thanks for the reply Oldguy48 it's my first project car
1950 Plymouth coupe Rulah Interior 4 03-12-2012 07:49 PM
1950 Plymouth 3 window coupe Rulah Hotrodding Basics 3 03-10-2012 09:28 PM
1950 plymouth businessmans coupe frame swap candidates..... Nubsauce General Rodding Tech 20 08-27-2011 07:16 PM
1939 Plymouth 5 window coupe conversion 39Plymouth Introduce Yourself 3 12-30-2005 07:55 PM
Front End conversion of a 48 Plymouth Coupe jbmoberl Suspension - Brakes - Steering 7 01-21-2005 06:03 PM
