brake drum mystery - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2011, 04:09 PM
brake drum mystery
I have a narrowed 9" ford in my hot rod. It has 11" x 2 1/4" brakes with 4 1/2" bolt circle. The axle hole is 2 7/8". I can't find a drum to fit it. Standard big car is smaller center. Am I stuck with getting the centers machined to fit?
Old 11-07-2011, 08:28 PM
BOBCRMAN@aol.com's Avatar
Probably. Or find some truck or econoline drums that fit the center hole and re-drill the stud holes in them.
Old 11-07-2011, 10:58 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
No.
Go to your favorite parts store and find the guy with a few grey hairs.
Explain your situation and ask him to find you a Brake Rotor & Drum Specification guide.
I tried to research this a bit from home myself. The only application that I stumbled upon was 1969 Mustang 11 x 2.25, 5 on 4.5, with a pilot hole dia of 2.780
NAPA nor Raybestos lists a drum with these dimensions, but FordRacing does.
M-1126-B
These are also available on Drivewire.com considerably cheaper.
The corresponding backing plate and shoes are M-2209-B
What *really* bugs me is knowing that the shoes are VERY common on the late 70's full-sized cars (i.e 78 T-bird) that also use that bolt pattern. (Those same shoes were used on 1/2 tons as well, but the bolt circle was bigger.) I can tell you that the Wagner part number to fit that particular car is a BD60378. Unfortunately, I have not been able to determine the pilot hole diameter.
However, I do believe that the aforementioned specification guide should contain that information.
Hope this helps!
Hmmm ... another thought. The early (pre-1978) Bronco's also used a "car" bolt pattern and some had the 9" diff as well, IIRC???
Old 11-08-2011, 06:09 AM
Thanks. I will do some more research.
No brake lights X3 new mystery DoubleVision Electrical 6 04-18-2010 12:56 PM
brake drum stuck 49dream Suspension - Brakes - Steering 9 05-08-2009 01:32 PM
stuck brake drum 49' willy Suspension - Brakes - Steering 8 04-20-2009 04:51 PM
repair brake drum? crownver Hotrodding Basics 11 03-24-2009 11:03 AM
Please solve the power brake mystery for me Randy Owens Suspension - Brakes - Steering 3 01-15-2003 03:12 PM
