brake drums - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2002, 07:21 AM
New Member
Post brake drums
dose any one out there know an easy way to get
frozeup brake drums off? my parts car has been
sitting for about 6or7 years. wheel won't evan
turn.
Old 09-02-2002, 07:42 AM
Madd Syntst's Avatar
American Madd Man
Post
Needs list:
Beer
Band aids
Ear plugs
WD-40 or equvilent
hammer
Big hammer
A seriuos MF hamma
Pry bar selection
start by soaking and having a beer. Tap all around continuously. As frustration sets in, step up to larger hammer.
Ooops, ice chest fullof ice and water. Just in case you hit and don't break the skin
Old 09-02-2002, 09:19 AM
hotrodit's Avatar
Talking
I'll second that, soak it well have a beer gently tap on outer rim of drum as it faces you that should free it up. If not get a big mother lump hammer & smack seven bales of ***** out of it!
go the lighter route first it would be best done with no damage, but brute force is the only real answer i'm afraid. good luck.
Old 09-02-2002, 09:37 AM
matty's Avatar
New Member
Post
guys, guys, 1 easy step.....sawzall....if that don't work air chisel
Old 09-04-2002, 09:17 AM
72 chevy's Avatar
Cool
Just checkin in with ya. Get em off? Did you back off the shoes by turning the adjuster wheel?
Old 09-05-2002, 06:22 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
Post
this is such a fun job!!!! ok as above make sure you back off the adjusters,then use a penetrating oil to spray the face of the drum at the studs to try and loosen them a little.
let it sit for a while(have a few frosties)
then take a hammer and firmly tap all around the edge of the drum. make sure you do it evenly or it will jam go slow and good luck
