Brake Drums - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2006, 06:48 PM
Brake Drums
I took off the wheels on my 49 Chevy pickup to check out the brakes.
The think the rear end is a mid 70's gm
One of the drums had the stud holes reamed out about twice the size of the wheel studs. The other side is normal?
Is this going to hurt anything. I would think once the wheel is draw-ed tight it should stay put. Any input would be appreciated
Old 07-05-2006, 06:50 PM
Wiki Edits: 31
I don't know what anyone would do that for but, it shouldn't hurt anything. if it bothers you, get larger diamater studs and drill the axle holes accordingly
Old 07-05-2006, 07:04 PM
There is a lot of things that they done on this truck that made me think
WHY? There is even a spacer on the side with the larger holes and none on
the other side? I'm putting on new rims so the spacer is gone.
Old 07-07-2006, 02:15 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
Sounds to me like you should break out the tape measure and string and check the geometry of that rear to the vehicle.
The only reasons I can see to have a spacer on one side and not the other is different offset wheels or an improperly installed rear.
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Crysler Brake Drums 35chev/302gmc Suspension - Brakes - Steering 0 05-25-2005 09:41 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
Ever had rear brake drums that refuse to come off? JunkYardFrog Suspension - Brakes - Steering 23 01-12-2003 11:13 AM
