Brake Help
I have a 85 monte carlo and changed the rearend to a ford 9" with disc brakes. The original brakes were drum on the rear. I changed out the proportioning valve to a disc-disc valve. The stock m/c does not seem to be working well and pedal travels almost to the floor. I think this is due to more volume needed from the m/c for the discs in the rear. What m/c should I use (part # please) and also will I need adapters for the lines going in to the m/c (where do I get these)? Any help appreciated. I need to get this darn thing on the road.
What kind of disc brakes? What calipers? Bleeders pointing up? Did you bleed all the air out? Is the e-brake hooked up and working properly? With your quick take-up master cylinder I highly doubt it is a volume problem.
bleeders are up, discs are 11" with hats from speedway motors, calipers are pre-metric mid size gm. I was told from other so-called knowledgable people that the m/c from a disc/drum setup could not be used as it would not push enough volume. I am ready to set fire to this project if I can't figure something out on these darn brakes. Also, no e-brake and I have vacuum bled them time and again.
So you are using front calipers in the rear (what make/model/year exactly)? Do you still have stock front brakes?
I believe the original mc port that connected to the front flowed more than the rear (drum ) port. Now, the rear needs the higher volume so you may try reversing the lines at the mc. Also you may investigate and determine if chevy offered a 4 wheel disc option in 1985; if so, maybe you can find the mc that was used for this option.
The rear calipers should be smaller than the front calipers. The front calipers are low drag calipers (which is why he has a quick take-up master cylinder) that retract the pistons more than older designs. The rear should never need more fluid than the front. GM would not have used a different master cylinder for rear disc brakes anyways. The rear port on the master cylinder goes to the front brakes from the factory.
Good point. I was thinking he had an aftermarket system like a 4-piston wilwood rear as I have, wich do require reversing the ports on the mc I am using. |
| master cylinder interchange | runn141 | Suspension - Brakes - Steering | 7 | 05-03-2009 05:15 AM |
| It's a Mustang II, but what's in it? And a brake problem . . . | hduff | Suspension - Brakes - Steering | 4 | 11-19-2006 06:00 PM |
| How Does This Stuff Work? | docvette | Electrical | 3 | 06-18-2006 03:00 AM |
| Wheel clunking and brake squeal | skizot | Suspension - Brakes - Steering | 29 | 10-09-2004 06:17 AM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
