Brake Help need for V8 S10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2002, 06:34 PM
New Member
Post Brake Help need for V8 S10
Anyone know what model master cylinder and brake rod bolt right up while doing away with the vacuum booster or do I need to be ready for a long day? I'm going to have a pretty big camshaft and the brakes will never work without removing it.
Thanks!
Bry
turbo@esn.net
Old 11-03-2002, 08:39 PM
BOBCRMAN@aol.com's Avatar
Post
get a master from a base line s-10 4cyl no power brakes. bolts in , better yet put a vacuum can and check valve on the line to the booster and you will have power brakes, hide the can in the fender well,
