Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake and Indicator wiring
Old 04-01-2013, 11:43 AM
Hotrod_Ford Hotrod_Ford is offline
Hi Everyone.
I read a few posts and found a few wiring diagrams on how to wire a 2 filament bulb for the brake lights and indicators. The problem is I dont have the same indicator switch as any of these diagrams and all of them show the brake wiring going through the indicator switch. My indicator switch has one supply and two output positions (Right, Left). If I connect the brake switch as on the diagram, the front indicators will also light up when the brake is applied and when I use the indicators both indicators will flicker. The only way to fix this is to make use of diodes. Any other suggestions?
