Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake and Indicator wiring
Old 04-01-2013, 02:47 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 2014
relays
The attached schematic shows typical turn signal switching when a dual filament bulb is used for brakes and turn signals.
The front bulbs must be switched seperatly from the rear.
The switching consists of (2) DPDT switches (double pole double throw, maintained).
If your existing switch must be retained, (2) relays could be used in place of the DPDT switches.
General purpose relays will be adequate for this. 12vdc coil with DPDT 10 amp contact rating.
vicrod
