Brake interchange info. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2007, 12:31 PM
tiburon62's Avatar
Hello, can I transfer the rear brake setup ,( from the backing plate out), from a '69 Chevelle with a 10 bolt to a '71 12 bolt rear?
Thought I would check with the experts before proceeding.Thanks Peter
Old 10-17-2007, 04:49 AM
Yes, 10-bolt and 12-bolt drum brake assemblies will interchange for this year.
This is an Olds site but has lots of info. Check it out.
http://www.oldsmobility.com/10bolt-tech.htm
Advantages -pitfalls of relocating parking brake to tranny hump Ripped Suspension - Brakes - Steering 1 09-01-2005 01:47 PM
Brake light problems RodFather Electrical 3 07-29-2005 10:45 AM
1997 blazer..Brake booster gone bad? RodFather Suspension - Brakes - Steering 2 06-17-2005 01:26 PM
Brake Pad Info Triaged Suspension - Brakes - Steering 0 03-27-2005 11:44 PM
Brake True? 5.0Towncar Hotrodders' Lounge 11 01-28-2003 11:36 AM
