I've kind'a been there done that with my 57 pickup. First you mentioned GM metric calipers, thats what I had on my Mustang II front end but the rotors (discs) were 10 1/2 in diameter. I upgraded to 11 inch rotors and earlier style larger calipers, late 60's early 70's GM calipers and my brakes work about 40% better (work good now). Also your power booster is probably a small diameter one about 8 inch or so, they really don't work that well because of the compact size. I don't have a power booster. Check with Ralph at ECI ,that where I got my 11 inch brake kit to fit Mustang II spindles
http://ecihotrodbrakes.com/ |
I Used to lived in the Hartford, CT area and remember that shop. I have a feeling that if anyone can find my weak link it is them. Thanks for the suggestion. I'll give them a call and see which direction would be a good starting place.
I'd really like to see your set up. I have had my 57 since 98 and have it just above "rattletrap" stage now. Thanks again. -Brian |
Pedal Ratio
Hey Sir, Not sure if you are using underfloor or firewall mounted M/C, but the pedal ratios are different between manual and power brakes. You maybe experiencing this problem. Heres a link to one company that includes a pedal ratio adapter for use with their power conversion kits.
http://nolimit.net/Instructions/PBC55.pdf olnolan |
Brake Conversions
I have researched the hell out of this stuff while trying to save up the money to finish mine. Because of the nature of my '57 build I can't do it incrementally. I have to buy all the suspension, steering and braking system components and do it all at one time. In SIR'S case, Maybe he should back up and evaluate the entire brake system. As COBALT pointed out, residual valves are required on under floor systems. Pedal ratio, residual valves, master/booster sizing, rear proportioning valve, etc. all need to work as a system to provide adequate braking power. For instance, in researching I found that some folks using the 7" or 8" boosters were not getting enough power assist. There are sources for small boosters that are double diaphragm (I think they were Mustang units)that provided plenty boost in a compact case. I'm hoping to install a well thought out system, to avoid rework and buying the parts twice. It seems that some of the kits available do not provide an optimum system its just a little better than the stock brakes. If I'm going to shuck out big cash to do a full brake upgrade, I want brakes that will sling me into the windshield if I get on the pedal too hard. Heres some links from my favorites, seems that alot of the really good stuff is in the back of the catalog; http://www.totalcostinvolved.com/ http://www.brotherstrucks.com/ http://www.golden-state-parts.com/new_parts.htm http://www.detroitspeed.com/ http://www.heidts.com/ http://www.zigsstreetrods.com/Pages/trucks.html http://www.charlotterod.com/ http://www.ecklerstrucks.com/ http://www.mpbrakes.com/ http://www.classicperform.com/4754chevtrk.html http://www.speedwaymotors.com/ http://www.posiesrodsandcustoms.com/ http://ecihotrodbrakes.com/index.html http://www.mpbrakes.com/uploads/cont...%20catalog.pdf http://www.wilwood.com/ http://www.lmctruck.com/ http://nolimit.net/departments.asp?dept=1032 http://www.southernrods.com/categories/brakes/ http://streetrodengineering.com/Prod...ekitsparts.htm |
| 1957 Chev Truck Fuel Tank | lbell101 | General Rodding Tech | 10 | 01-15-2013 05:24 PM |
| 57 chevy panel truck | jakmbj | General Rodding Tech | 3 | 04-19-2010 05:11 PM |
| 1972 chev 3/4 pull truck | full pull bob | Introduce Yourself | 2 | 08-19-2008 07:46 PM |
| Anybody done the P/S Conversion on 57 Chev PU? | lbell101 | Suspension - Brakes - Steering | 1 | 06-25-2006 09:52 AM |
| door latch options for 57 truck? | murrsue | Body - Exterior | 7 | 02-21-2003 06:16 PM |
