Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake Issues, C3 Corvette m/c Q's...
Old 11-17-2012, 02:00 PM
LATECH's Avatar
LATECH LATECH is offline
The only thing you changed was the diameter of the front caliper pistons.
I would stillthink there is trapped air in the system.
Before that you had the high hard pedal, the difference in the bore of the caliper pistons size is pretty big, more fluid is required.
You do have the Large reservoir part of the master going to the fronts right?
Fact is stranger than Fiction
