Check the sealing surface on the caliper where the banjo bolt attaches. I had a caliper once that was a factory rebuilt that would not seal at the banjo bolt connection no matter what I did. Kinda like your current situation. I took it back to the parts store, & the guy right away showed me that part of the seal surface on the caliper had slightly eroded away, and that was worsened by the shot-blast process the rebuild factory used to get the casting cleaned up. He said that was a common problem on rebuilt calipers. Jon http://1972vega.wordpress.com/ |
Most likely the replacement copper washers are junk. The ones that come with replacement calipers are very problematic.
We always use the original ones. You may want to check to be sure all surfaces are clean. If they are try a set of copper washers from the dealer.
Artificial Intelligence is no match for Natural Stupidity Chet |
most of the oem washers are annealed , the overseas cheapies are work hardened from stamping , have to anneal them by heating with a torch and dropping them in to water ( it the reverse of hardening steel )
are you sure that the banjo bolt & brake caliper are setup to use the same diameter & thread pitch?
it requires a great deal of compression force to create sealing grooves in the copper crush washers. if the banjo bolt starts to slip on the caliper threads, you might not be able to get the parts to lock together properly. used copper crush washer with grooves cut into it from banjo bolt & caliper threads ![]() banjo bolt with a couple crush washers on it ![]() brake flex hose seal surface for crush washer
i've also seen remanufactured calipers supplied with the wrong diameter crush washers too. if the crush washer isn't wide enough to catch a couple grooves on the flex hose, banjo bolt & caliper seal surfaces, you'll get leaks.
| Advices on brake system repair 78 Monte | rack | Suspension - Brakes - Steering | 5 | 01-12-2009 08:32 AM |
| Door alignment driving me crazy | americanLT1 | Body - Exterior | 7 | 08-14-2007 03:06 PM |
| 350 TBI spark problem driving med crazy!! | Erst | Engine | 12 | 04-26-2007 10:18 AM |
| Spindle interchanges | bskaggs | Suspension - Brakes - Steering | 11 | 06-05-2006 01:29 PM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
