Brake lever return spring? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2012, 07:21 PM
sedanbob's Avatar
This is my master cylinder/ brake lever setup on my sedan. I do not have an external return spring. My brakes seem to work just fine, and the pedal returns nicely (as far as I can tell). I keep seeing posts talking about return springs. Question is, do I really need one? I have GM discs up front and Ford 11' drums in the rear. Thanks!
Old 10-27-2012, 08:21 PM
327NUT's Avatar
My '32 TCI setup is similar to yours and there's no return spring, never saw a modern hotrod with one.
Old 10-27-2012, 09:39 PM
sedanbob's Avatar
I saw several on another website - around the pushrod. I didn't see why I'd need one. Your answer confirms what I thought - Thanks!
Old 10-28-2012, 06:02 AM
Irelands child's Avatar
I don't have one on mine though there is a 'mod' that I've seen that uses a spring around the push rod. I have a spring just in case, but so far haven't seen the need. Simple to add if you feel that it's needed.
Irelands child
Old 10-28-2012, 06:10 AM
streetrodderbn's Avatar
Certifiable Streetrodder
The reason for the return spring is to not rely on the master cylinder internal spring to return the pedal. I always put one on, it's cheap insurance, I have fixed more than one customer car that has dragging brakes as the pedal assembly is too heavy and the internal master cylinder spring has become weak and wont allow the master cylinder piston to return fully,maintaining pressure on the brake calipers/drums.
Old 10-28-2012, 07:32 AM
Wiki Edits: 27
brake lites ?
If you have a mechanical brake lite switch, your lites could blink on or stay on while driving. The brake pedal that came with my Rocky mountain Brake Kit has a tab for a return spring.
Old 10-28-2012, 08:29 AM
delawarebill's Avatar
spring ???????
let me say this about that.. when i first finished my bucket i didn't use a return spring either.. took it out for a test drive and it didn't feel right.. needed more power to get running.. after the tow truck brought it back ($60). i found out my peddle did not return far nuff and was closing off the brake line opening and holding pressure... a $3 return spring solved that problem..
Old 10-28-2012, 02:40 PM
sedanbob's Avatar
I have tried lifting the brake pedal with my toe while driving, to make sure it is returning fully. So far, it has been, every time. Looking at the original factory setups, I see lots of under-the-floor master cylinders with a rubber boot on the shaft, but no springs. I guess I'll keep checking, and add one later if necessary. Thanks for everyone's input!
Old 10-29-2012, 06:42 PM
302 Z28's Avatar
I have on my 34 that goes around the actuation pushrod and it works just fine. It was another one of those things I worried about when building the car that turned out to be non issues. I have also seen posts that suggested to not have a return springs will be hard on your MC.
Vince
Old 10-29-2012, 06:57 PM
sedanbob's Avatar
Vince, Appreciate the input. What puzzles me is that I can't find any original under the floor mastercylinders/brake pedal arms that have springs. I have only seen them on streetrods. Firewall mounted masters seem to all have return springs.
Old 10-30-2012, 12:30 PM
302 Z28's Avatar
I found the same thing I guess that is a nich filled by the return spring arrangement I used.
Vince
dual return spring for holley ???? cutthroatkid Hotrodding Basics 2 08-26-2009 12:23 AM
Using a lever type spring compressor on vortec heads? ForceFed86 Engine 5 05-12-2009 01:08 PM
Q-Jet secondary return spring crash Engine 2 01-13-2009 02:29 AM
throttle return spring sbc w/ holley KNanthrup Engine 7 12-05-2005 05:59 PM
throttle return spring bracket brian400ex Engine 2 02-19-2003 02:34 PM
