Brake Light - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-03-2002, 06:05 PM
66chevy2ss's Avatar
Post
Helrazr:
It turns out it was the turn signal switch that was causing the left brake light to not work. I never would have guessed that on my own.
I replaced the switch. Of course, the switch doesn't exactly fit the "shroud" that was on the steering column, so the wires and gadgets are all exposed. Oh well, I like that "raw" look!
  #17 (permalink)
Old 09-03-2002, 06:11 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
Post
well i'm glad its fixed. i never would have guessed that would be the problem.
i have to take my hat off to al from autorewire i've been on this board for about 6 months and he's never been wrong yet, al you da man!!!!!
  #18 (permalink)
Old 09-03-2002, 08:44 PM
Old Fart
Post
Hey 66chevy2ss
There should be two different turn signal switches for your model, or at least there is for the full size Chevy in '62. So it would just be a matter of getting the correct switch.
helrazr3, thanks for the kudos but you guys just wait until I really blow it on something and then I'll bet I get roasted good. hehehe
al
Al Campion
NORCAP Sales and Services
AutoRewire.com and Hot Rod Resins
P.O. Box 36
Topaz, CA 96133
209-481-6496
  #19 (permalink)
Old 09-04-2002, 04:27 AM
66chevy2ss's Avatar
Post
Thanks Al,
I thought maybe I could just cut another hole in the existing shroud!
It works, that's what is most important. Plus I don't want to spend too much here.
  #20 (permalink)
Old 09-13-2002, 07:46 PM
46_stvblt's Avatar
Post
I've been reading the posts about brake lites and turn signal switches, Here is my problem.. new wiring kit installed..turn signals work..brake lites work until I turn on the turn signal..then the turn signal works but the opposite brake lite goes out.Could this problem be the same fix (ie) put in a new switch? ....GK Thanks for your expertise
« Help? | run on »
