brake light flashing - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2004, 04:14 PM
grapro's Avatar
Last journal entry: Out in the Sun
I've got a 91 chevy pickup and my brakelight warning indicator just started flashing out of nowhere and will not quit . I checked fluids and everything seems alright any ideas?
Old 10-13-2004, 05:13 PM
curly5759's Avatar
It may be trying to tell you about an antilock brake problem. If I remember correctly, some early GM systems flashed the red brake warning light, later systems the amber abs light
Old 10-13-2004, 07:07 PM
Restore60s's Avatar
Flashing brake light
I think your truck still had the RWAL anti-lock brake system. You can try and clear the codes out by disconnecting the module under the hood and clearing it out. Should be mounted under the master cylinder. If it comes back on flashing then you will have to get the codes read. Good thing is that it has no effect on your regular braking system.
Old 10-14-2004, 11:08 AM
302 Z28's Avatar
Anti Lock brake problem. Hope it isn't your module.
Vince
Old 10-15-2004, 07:25 AM
grapro's Avatar
Thanks guys
unplugged my module and plugged it back in and it worked
