brake light pressure switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2007, 12:21 PM
I have a 50 plymouth,6 volt,inline pressure brake light switch. I was wondering if all the switches are the same or do they have diffrent thread diameters? Can I use any 6 volt switch that is inline? Thanks
Old 04-25-2007, 02:27 PM
They are a NPT thread ... so most any 6 volt one will thread in ... the electrical hook up may vary ... but NAPA most likely has one or can get one ...
Old 04-25-2007, 05:47 PM
Thank from the info. I will be changing the leads going from the switch,so I can grab the rite terminals to fit on the switch. Thanks again.
lock-up converter disable 54p.u. Transmission - Rearend 5 12-14-2006 02:19 PM
3rd Brake Light Hook-up 39chevy Electrical 1 05-13-2006 02:12 PM
Wiring a Tilt Mercury Switch for Trunk Light JohnTN Electrical 7 05-11-2006 03:06 PM
brake light on, could it be a bad master cyl Turbo Terror Suspension - Brakes - Steering 4 03-07-2006 07:04 AM
mechanical brake light switch colobronco Electrical 2 08-18-2004 05:54 PM
