Brake light problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2007, 07:19 PM
Brake light problem
I have a 1987 Monte Carlo adn I'm having an issue with the brake lights. When you turn the headlights on, the brake lights come on except for the third brake light. When you push the brake with the lights on, the third brake light comes on. So the two taillight brake lights are always on. Also, if the headlights are not on, when you push the brake, the parking lights come on. Any ideas on this problem?
Old 12-17-2007, 07:24 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
Check all the grounds,They will make things go crazy.
Old 12-17-2007, 08:49 PM
grandpaws 57's Avatar
"Don't need no V/8"-grandpaw
bulbs
check bulbs to see if one filliment is touching another.Did this start all of a sudden?Problems in past?
Old 12-18-2007, 07:35 AM
31 five window
Last journal entry: Moving along with patch panels.
Are you using LED tail light bulbs?
Old 12-18-2007, 02:27 PM
It didnt do it when i bought it, but I was missing a bunch of bulbs so i replaced them. Could this be because of a wrong bulb?
Old 12-18-2007, 02:41 PM
vettedreams2001's Avatar
Ethylene Glycol and OJ, Mmmm!
IMO I would check the bulbs to see if they have the correct number of filaments and then go from there.
Old 12-18-2007, 05:43 PM
T-Bucket, Corvette, Mustang
Also, I have seen where a dual filament bulb (parking and brake light in one bulb) can be inserted 180 degrees out of phase in the socket. This will cause brake lights to come on when the parking lights / headlamps are on, and cause the parking lamps to come on when the brake pedal circuit is activated. If you have recently replaced the bulbs, you might want to take the bulbs out and turn them half a turn before inserting to see if that may be the issue.
What will cause the BRAKE warning light to come on? colin911 Engine 5 09-01-2006 03:00 PM
Bench testing brake light switch-? 31 Ford A Electrical 2 08-23-2006 05:24 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Lambert Flush Mount 3rd Brake Light 35WINDOW Body - Exterior 1 05-19-2006 09:52 AM
Major Brake Problem... HELP ME! 98rocket Suspension - Brakes - Steering 8 03-17-2003 05:22 PM
