Brake light problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2011, 04:43 AM
Brake light problem
Need help with brake light issue. When the ignition switch is on and the car is not running, the rear taillights, signals and brake lights work fine. When I start the car all the lights go to bright lights as if the brake light was stuck, but its not. Two wires on the brake switch seem to be connected correctly.
Old 10-17-2011, 06:07 AM
Thats a strange one right? Just something to try. With the motor running and lights gone to bright try removing the fuse to the brakes and see if theyre still on. Then you can take the other fuzes out one at a time and if you find another circut is causing it the lights will go out. Once you find the circut thats feeding them it might be easier to find where theyre touching.
If they go out when you pull the brake light fuze put it back and still try taking the other fuzes out one at a time till you find one that affects the brake lights and lets them go back to normal.
Old 10-17-2011, 08:03 AM
brakes=and fuses.
Thanks, i will try that.
Old 10-17-2011, 03:57 PM
EOD Guy's Avatar
What's the vehicle? I'd ck the tail light harness to start with
Brake light problem 88 mercury 36int Electrical 3 07-03-2011 12:03 PM
brake light problem cornfieldcars Electrical 20 10-19-2010 07:54 AM
60 Impala Brake Light Problem Strifex Electrical 1 08-07-2008 09:10 PM
Brake light problem mightycarlo10 Electrical 6 12-18-2007 05:43 PM
55 belair brake light problem sparti80601 Electrical 2 06-03-2007 09:55 PM
