Brake light problem 88 mercury - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2011, 11:37 AM
I have an 88 mercury grand marquis. The brake lights don't work. The turn signals work ok. They use the same bulbs. I checked the fuse its ok. I don't know where the brake light switch is to check it. any other ideas.
Old 07-01-2011, 11:57 AM
66SSImp454's Avatar
Justin
Located on the brake pedal just under the dash
Old 07-01-2011, 12:38 PM
found swithch
ok I found the switch, but I'd have to be a midget to get to it. Is there some trick to getting to it so I can check if its working correctly. I can't even get my hand on the connector.
Old 07-03-2011, 12:03 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
How did you check the fuses?
Use a voltage tester to make sure the brake light fuse is good. The turn signal fuse is a different because the brake light fuse is hot at all times and the TS fuse is hot when the ignition is on.
If it is blown there is a reason.
You may need to hire a midget to test the brake light switch.
vicrod
brake light problem cornfieldcars Electrical 20 10-19-2010 07:54 AM
60 Impala Brake Light Problem Strifex Electrical 1 08-07-2008 09:10 PM
Brake light problem mightycarlo10 Electrical 6 12-18-2007 05:43 PM
55 belair brake light problem sparti80601 Electrical 2 06-03-2007 09:55 PM
TRANny & O/D light problem on 96 mercury mystique grover805 Transmission - Rearend 9 08-24-2004 11:59 PM
