Brake light problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2005, 06:33 AM
RodFather's Avatar
I smell like a hotrod!
Last journal entry: windshield
I am pretty sure my new brake switch is toast, but I am wondering what caused it if everything works when I replace it.
May not be the problem at all.
Brake lights were working, and then I hooked up my headlights. My problem at this point was the tail lights and brake lights were the same (lights stayed bright when I braked and you couldn't tell I was braking).
At this point I switched the wires around on the bulb sockets thinking I had them backwards. That worked brake, tail light, Turn signal all worked. That was two days ago.
I tied up my wiring and was trying my headlights last night when I noticed the tail lights were on, but no brake lights ( I haven't bypassed the brake switch yet to make sure the lights are working).
I am sure I am missing something and it's probably wiring to my bulbs. Fuses good, bulbs good....any suggestions?
Old 07-28-2005, 08:13 AM
RodFather's Avatar
The brake switch is for a 1983 monte carlo and has two electrical prongs on the side and two on the end. I am using the two on the side.
Old 07-28-2005, 10:04 AM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
Use the 2 on the end, I believe the 2 on the side are to kick off the cruise control.
Swap the wires around and let us know if it worked or not.
Later,
WEIMER
Old 07-29-2005, 10:45 AM
RodFather's Avatar
Problem fixed.
Apparently, when I was cleaning up the wiring I cut the brake switch power wire instead of a zip tie.
bad brake light switch on master cylinder? flamedfordbronco Electrical 3 07-10-2005 05:34 AM
Brake booster problems shockers69 Suspension - Brakes - Steering 8 01-27-2004 04:32 PM
Wilwood Brake problems Pro57 Suspension - Brakes - Steering 9 06-25-2003 08:48 AM
CHRYSLER BRAKE BLEEDING PROBLEMS daross Suspension - Brakes - Steering 10 05-07-2003 11:52 AM
Light problems Wmarden Hotrodders' Lounge 8 11-28-2002 04:55 AM
